  3. converting dra file to padstack
  • State Verified Answer
  • Views 12830
myil17
myil17 over 4 years ago
Is there a way to convert.dra file to padstack file? I manipulated one of the IGBT pin ,add some copper, but I would like to save it as a padstack so I can make change on similar pins at once.
Or any other ideas?
BR
  • JuanCR
    JuanCR over 4 years ago +2 verified
    Hey myil17! Converting the file is not possible but you can export the padstack that you have modified (File -> Export -> Libraries). Then you can place the modified padstack wherever you want ... for…
  • JuanCR
    JuanCR over 4 years ago in reply to myil17 +2 verified
    Ok, why don't you try opening Padstack Editor directly from Windows Start Menu and create a new file in the same folder as your PCB project. Then you can create/modify the padstack you need there. And…
  • JuanCR
    +2 JuanCR over 4 years ago
    Hey myil17! Converting the file is not possible but you can export the padstack that you have modified (File -> Export -> Libraries). Then you can place the modified padstack wherever you want ... for instance, you can replace all existing padstacks of one type by this new modified one (Check the option in Tools -> Padstack -> replace ...)
    • Vote Up +2 Vote Down
  • myil17
    0 myil17 over 4 years ago in reply to JuanCR
    I couldn't export the padstack. what I did so far is I opened a new mechanical symbol file and edited the pad out there(added some extra copper). what should i do next ?
  • JuanCR
    +2 JuanCR over 4 years ago in reply to myil17
    Ok, why don't you try opening Padstack Editor directly from Windows Start Menu and create a new file in the same folder as your PCB project. Then you can create/modify the padstack you need there. And then you can add it to any .dra file you create in that folder. Make sure that you have your padpath variable include all pads from the current folder (just add a dot to it ".").
