  3. Delay Tune Option - 17.4 OrCAD PCB Designer Standard
  • Views 2286
arunet
arunet over 4 years ago
We are using 17.4 OrCAD PCB Designer Standard and we need the delay tuning operation for the PCB design.
We can able to see the delay tune option in the design parameter section but there is no such (delay tune) sub-option in the Route section. Kindly let us know how to use the delay tune option in 17.4 OrCAD PCB Designer Standard.
  • steve
    0 steve over 4 years ago
    For this feature you would need at least and OrCAD PCB Designer Professional license or higher (Allegro PCB Designer). This is not available in the Standard license. Take a look at Matrix - Parallel Systems (parallel-systems.co.uk) which shows you the differences between the license levels. Any delay tune (or length matching) would need to be added manually (Route - Connect then draw the delay bumps in you need without the Professional license.
