  3. Differential pair spacing DRC
  • Views 13321
kakri
kakri over 4 years ago
I have defined a differential pair having a primary gap of 6 mil and I wanted line to line spacing 20 mil. The both nets are defined as differential pair and the constrains are applied. I was able to draw the differential pair with the required primary gap (6 mil) but a line to line spacing DRC error is coming mentioning
Constraint value: 20 MIL
Actual value: 6 MIL
Kindly provide a solution.
  • Vipulc
    0 Vipulc over 4 years ago
    When routing differential pairs with a gap less than the line-to-line spacing constraint, you must set the Min Line Spacing column value to be equal to the smallest diffpair gap including any neck gaps and (-) Tolerance settings to get rid of the L-L DRCs.
    Here is an example for reference:
    Typical line-to-line spacing = 10.00
    Primary gap = 8.00
    Neck gap = 6.00
    (-) Tolerance = .01
    Min Line Spacing = 6.00 - .01
           = 5.99
    Once the "Min Line Spacing" is specified correctly, the L-L DRCs will not be generated.
