  3. SMT or FIDUCIAL PAD (without drill) on multiple internal...
  • Views 12360
SMT or FIDUCIAL PAD (without drill) on multiple internal layers
mir0mik
mir0mik over 4 years ago
Hello Everyone!
I'm searching for a solution how to create a PAD without a drill hole but present on multiple layers (e.g. TOP + inner...)... The only way I found how to do the is modify THT pad to zero diameter drill size, but this generate errors Disappointed
Thanks for advice/ideas!
Miro
  • oldmouldy
    0 oldmouldy over 4 years ago
    You could use a Mechanical Hole as the Padstack Type. Add the named Layers to the Design Layers and define the required Pads. There are warnings generated when the Padstack is saved but the Padstack will be saved anyway and can then be used. Since you know the design intent, you can ignore the warnings. The cross-section of the destination Symbol / Board must have a match for the Design Layers defined in the Padstack, otherwise the Padstack won't load.
  • mir0mik
    0 mir0mik over 4 years ago in reply to oldmouldy
    Thanks, I will check. It would be nice if Cadence added "Allow multiple layers" under "Options" in SMT PAD Stack :)
  • oldmouldy
    0 oldmouldy over 4 years ago in reply to mir0mik
    Then it wouldn't be an SMT Padstack, would it? If you are dealing with multiple cross-sections, PCB Editor will "work out" which is the "outer" layer and adapt the Padstack accordingly. That should also be true for Embedded components with the Miniaturization Option but it's unlikely that a fiducial would be needed in that case.
  • DavidJHutchins
    0 DavidJHutchins over 4 years ago in reply to oldmouldy
    I think the pick&place machines would need multiple fiducials to correctly align/orient the board for embedded components placement ( especially with panelized designs )
  • SandeepVarrier
    0 SandeepVarrier over 4 years ago in reply to oldmouldy
    Fiducials are provided in a minimum of 3 numbers to mark the XY coordinate of the PCB , Main fiducials are placed in the corners of the PCB, certain fine pitched components have local fiducials eg BGA.
    Solder mask is kept open for these smd fiducials.
    The pick and place machines take references from the fiducials.
