  3. Measure pad size on Allegro Free Viewer 17.4
  • State Verified Answer
  • Views 19112
HAIO
HAIO over 4 years ago
Dear Team,
I need to measure the length and width of a pad as shown in the below image.
Could you please help me with how to do it?
Regards
HARI
  • DavidJHutchins
    DavidJHutchins over 4 years ago +1 verified
    I wouldn't waste my time trying to do this in the new version of 'Allegro Free Viewer', IMHO it's crippled... I would revert to the older version named 'allegro_free_viewer_classic', which looks looks…
  • DavidJHutchins
    +1 DavidJHutchins over 4 years ago
    I would revert to the older version named 'allegro_free_viewer_classic', which looks looks like the standard Allegro tool, it also has a 'show measure' toolbar icon & the 'Display>Measure' menu
    Start the 'show measure' command, then in the Options pain change the Active Class & Subclass to 'Etch' and 'Top'
    then place the cursor over the lower-left corner of the pad & RMB>Snap Pick To>Pad Edge Vertex
    then place the cursor over the upper-right corner of the pad & RMB>Snap Pick To>Pad Edge Vertex
    The Delta X & Delta Y values should give you the pad dimensions...
  • HAIO
    0 HAIO over 4 years ago in reply to DavidJHutchins
    Thank you....it is working ...now I am able to verify footprints properly...Thumbsup
