  3. renaming refdes
  • State Verified Answer
  • Views 12635
renaming refdes
masamasa
masamasa over 4 years ago
hello
is there a way to rename reference designators?
i would like to rename a refdes from CC1 to CC3, for instance, where CC3 is not yet assigned.
when i try to rename it, it says, "symbol is already assigned."
  • DavidJHutchins
    DavidJHutchins over 4 years ago +1 verified
    Instead of using Logic>Assign Refdes try using Logic>Part Logic..., pick the component, change the refdes to an unused value, then pick the Modify button, followed by the OK button
  • DavidJHutchins
    +1 DavidJHutchins over 4 years ago
  • masamasa
    0 masamasa over 4 years ago in reply to DavidJHutchins
    thank u david. it works.
