  3. Allegro: Tip of the Week: Fixing/Unfixing elements in the...
  • Subscribers 163
  • Views 7921
Allegro: Tip of the Week: Fixing/Unfixing elements in the design
PCBTech
PCBTech over 4 years ago
You can easily add and remove the Fixed property from an object.
Fixing the location of a single element
Move the mouse over the element (symbol, via, etc.) and select the Fix command from the context-sensitive RMB menu.
Quickly unfixing several elements
There are two ways to achieve this depending on the scope of the command:
  1. Click the Unfix icon () and select an element or group of elements. This will effectively affect only the selected elements.
  2. Click the Unfix icon and right-click anywhere on the design. Select the Unfix All command from the context-sensitive RMB menu. This will delete the Fixed property from ALL the elements of the design regardless of any preselection.
Team PCBTech
Cadence Design Systems
