  3. can't export library
  • Views 1686
myil17
myil17 over 4 years ago
I can't export the library. Have any idea why i can't ?
  • DavidJHutchins
    DavidJHutchins over 4 years ago +1
    Can you try doing running the 'dump_libraries' command directly from the OS level? Below is an example session from my Win8.1 laptop: c:\Users\David1\Documents> c:\Users\David1\Documents>cd /D %SIGRITY_EDA_DIR…
  • DavidJHutchins
    0 DavidJHutchins over 4 years ago
    c:\Users\David1\Documents>cd /D %SIGRITY_EDA_DIR%
    D:\Cadence\SPB_17.4>cd share\pcb\examples\board_design
    D:\Cadence\SPB_17.4\share\pcb\examples\board_design>md symbols
    D:\Cadence\SPB_17.4\share\pcb\examples\board_design>cd symbols
    D:\Cadence\SPB_17.4\share\pcb\examples\board_design\symbols>dump_libraries ..\cds_routed.brd
    Performing a partial design check before saving.
    Writing design to disk.
    'hole096' saved to disk.
    '60c85c35d' saved to disk.
    'smd50_25' saved to disk.
    'smd25_50' saved to disk.
    'smd30_55' saved to disk.
    'smd50_63' saved to disk.
    'smd30_94' saved to disk.
    '60s85c35d' saved to disk.
    'smd50_87' saved to disk.
    'via' saved to disk.
    'pad60sq36d' saved to disk.
    'smd65rec13' saved to disk.
    'pad60cir42d' saved to disk.
    'pad60cir36d' saved to disk.
    'tr_80_60' saved to disk.
    'tr_36_24' saved to disk.
    'tr150' saved to disk.
    'conn50' saved to disk.
    'soic14' saved to disk.
    'soic16' saved to disk.
    'crys14' saved to disk.
    'smdcap' saved to disk.
    'pqfp100' saved to disk.
    'smdres' saved to disk.
    'soic20w' saved to disk.
    'lcc28' saved to disk.
    'zip20' saved to disk.
    'cap400' saved to disk.
    'plcc32' saved to disk.
    'outline' saved to disk.
    'asizeh' saved to disk.
    'notes' saved to disk.
    The dump_libraries process has completed
