  3. Full round shape and route keepout problem
  • State Verified Answer
  • Views 12658
soll
soll over 4 years ago
There is an issue that I encounter quite often when using full round shapes. As you can see in the images below, the shape (green) is drawing some kind of fillets in the edges of the route keepout shape (pink).
This does not happen every time. On the second picture, you can see that the shape is not generating copper inside of the route keepout.
Both images are 0603 capacitors (our footprint has a route keepout between the pads). Both GND shapes have the exact same parameters (I copied the shape with no error to create the shape with an error). Orientation of the component doesn't change anything. I tried updating the shape, updating all shapes (from DRC window), updating DRCs, I did a DBdoctor check, I tried changing constraints...
I am using Allegro 17.2
Bad Keepout
Good Keepout
Why are shapes randomly filleting inside route keepout ? How can I prevent that ?
Thank you.
  • SandeepVarrier
    SandeepVarrier over 4 years ago +1 verified
    Did you try using acute angle trim control in shape parameters > Void Control> A cute angle trim control > Full round. can you also try using the variable “shape_full_round_expand_rko” under Setup…
  • SandeepVarrier
    +1 SandeepVarrier over 4 years ago
    Did you try using acute angle trim control in shape parameters > Void Control> Acute angle trim control >Full round.
    can you also try using the variable “shape_full_round_expand_rko” under Setup > User Preferences > Shape > General.
  • soll
    0 soll over 4 years ago in reply to SandeepVarrier
    hello, yes the shapes are Full Round. The problem isn't there when using the other "acute angle trim control" options. But our customers don't want sharp angles on the edges of the shapes so I use the full round option.
    I tried the User pref setting you provided and it works ! Thank you, didn't thought about checking the User preferences for that kind of thing.
