  3. How to disable cross-probing in PCB designer professional...
  • Views 13916
How to disable cross-probing in PCB designer professional / standard ?
nutron
nutron over 4 years ago
I noticed that in PCB designer professional and standard 17.4-2019 S022  there is no option under the setup menu to disable cross-probing.
In PCB designer (non professional / standard) there is a menu item called disable cross-probing.
Is there a way to temporarily disable the cross-probing feature in PCB designer pro ?
The only thing i found so far is to disable the whole "inter tool communication in capture.
  • mahimag
    0 mahimag over 4 years ago
    Set user preference variable "allegro_no_xprobe" to Yes to disable cross probing
  • nutron
    0 nutron over 4 years ago in reply to mahimag
    PCB designer professional has a function for that. It just has no dedicated menu item for it.
    1. go to %home%   ->  AppData\Roaming\SPB_Data\pcbenv
    2. Edit env file
    3. add this :  funckey x xprobe toggle     bellow   "source $TELENV"
    The x keyboard key will now toggle ON/OFF cross-probing in PCB designer.
