  3. How to create sequent stacked buried via by one click
  • Subscribers 166
  • Views 12376
ichliebedich
ichliebedich over 4 years ago
Hi All
I created the buried via like below with auto generating function.
and I want to sequent bbvia if I place L2 to L4 by one click like below
I followed this video : https://www.youtube.com/watch?v=Mu5pyUxqp50 but I coudn't find that I want to do
If I press the Layer_4, then create sequent b/bvia from Layer1 to Layer4 at once without manual multiple click (refer to pic below)
regard
  • steve
    steve over 4 years ago +1
    Try moving the standard via to the end of the vialist. The vialist order is key. Once you do this it will add the vias sequentially..
  • steve
    0 steve over 4 years ago
  • marcozeta
    0 marcozeta over 4 years ago
    You need to enable the Pad-Pad connection and you have to set to "All allowed" or "via-via". Then when you will select the layer, the desired stacked via will be added.
