  3. Allegro - Tip of the week: Wondering how to see the constraints...
  • Subscribers 163
  • Views 2343
Allegro - Tip of the week: Wondering how to see the constraints between any two objects?
PCBTech
PCBTech over 4 years ago
Do you want to see how a constraint resolves between two objects?
Use Display > Constraint  , and then window-select the two objects to obtain spacing resolution. You can select a single object for physical constraint resolution.
In the following example, cline segments of two nets, A2 and A9, are window-selected to obtain spacing resolution. The air gap distance is shown in the middle section of the report.
Team PCBTech
Cadence Design Systems
