  3. deleting lines after compose shape
  • State Suggested Answer
  • Answers 1
  • Views 13084
myil17
myil17 over 4 years ago
Hi Everyone,
I imported a dxf file choosing outline and made some changes by using "compose shapes" option. But ,I couldn't figure out how to delete the lines that are created just after import. The lines are still there even though I compose shape. Is there a way to delete them?
  • excellon1
    excellon1 over 4 years ago +2
    Hi When you compose the shape based on lines either drawn by hand or imported via a dxf to the board outline class those lines will remain after you compose the shape, to remove them uncheck everything…
  • excellon1
    0 excellon1 over 4 years ago
    Hi
    When you compose the shape based on lines either drawn by hand or imported via a dxf to the board outline class those lines will remain after you compose the shape, to remove them uncheck everything in the find filter except lines,  window select them so they highlight and then right click delete to remove them.
    • Vote Up +2 Vote Down
  • Schulz Jordan
    0 Schulz Jordan over 4 years ago
    While composing shape in the options tab check " delete original lines" this will automatically deletes lines
