  3. component footprint as a new board design
  • State Suggested Answer
  • Answers 1
  • Views 10586
myil17
myil17 over 4 years ago
Hi Everyone,
I would like to use a component's footprint as a new board design. What is the best way to do it?
Due to the components shortage, one of the component will be replaced with a printed circuit board.
Best regards
  • Wild
    0 Wild over 4 years ago
    I believe what you are trying to do is fit a different part package into an existing board design with a different package footprint.  If my understanding is correct: I have done this a couple of times:
    Example we had a device in a 48QFN but wanted to prove in the repackage of the same die in a smaller package 28QFN
    My solution was to create a castellated board.  The bottom side had 48QFN footprint with mirrored pin out. The top side had the new footprint matching the new device.  I need a few inner layers for routing and the thermal via structure of course had to be changed to accommodate smaller epad of the 28QFN.  I hop this helps.
    https://www.eurocircuits.com/blog/castellations-on-a-pcb/
