  3. How to revert moving pins in PCB to a one click operation...
  • Views 10772
How to revert moving pins in PCB to a one click operation?
l3hrbonini
l3hrbonini over 4 years ago
I believe I've accidentally changed a UI setting somewhere in PCB editor.  When editing a DRA with the move tool selected, I used to be able to click on a pin to both to select it and to pick it up by it's origin.
After the change I have to select the pin and then do a snap pick to > pin.  I've set a persistent snap to pin, but I still have to double click the pin to pick it up, and unintentional snaps constantly occur.
Any idea how I can restore one-click select and pick of pins while editing the DRA?
  • steve
    0 steve over 4 years ago
    Invoke the Edit - Move command from the menu then in the Options pane change the Point dropdown to sym origin and then right click - Done to store this setting.
  • Schulz Jordan
    0 Schulz Jordan over 4 years ago
    You can restore cadence default settings as follows. View - UI settings - Reset Ui to default
