  3. Comparing two pcb layout databases in Allegro pcb edito...
  • State Verified Answer
  • Answers 1
  • Subscribers 166
  • Views 17566
Comparing two pcb layout databases in Allegro pcb editor
HSID
HSID over 4 years ago
I am using Allegro PCB Editor 17.4, is there a way to compare two pcb databases to see differences.
If there is, what items does it look to compare.
  • HSID
    HSID over 4 years ago in reply to Schulz Jordan +1 verified
    I know I can compare netlists against pcb databases but can i compare a .brd file to another .brd file. Thanks
  • HSID
    HSID over 4 years ago in reply to SandeepVarrier +1 verified
    I do not believe we have that license. What does the pcb to pcb comparison check for and does it enable you to create a report of the differences. Thanks
  • RFinley
    0 RFinley over 4 years ago
    Allegro is designed to re-import 274x gerber to the board class for verification.
    There's a rapid adoption kit on Support.cadence.com.
    "Allegro PCB Editor Artwork to Etch Compare with Custom Subclass Layer."
    Or, do you have CAM350?
  • Schulz Jordan
    0 Schulz Jordan over 4 years ago in reply to RFinley
    You can use the PCB design compare option within the PCB editor. It sorts the differences by net names
  • HSID
    +1 HSID over 4 years ago in reply to Schulz Jordan
  • SandeepVarrier
    0 SandeepVarrier over 4 years ago in reply to HSID
    Yes you can compare PCB's to PCB's you need to have productivity toolbox license , to know if the feature is enabled please type in tbx descompare in the allegro command window
  • HSID
    +1 HSID over 4 years ago in reply to SandeepVarrier
