  3. Allegro – Tip of the week: Save and Restore your UI set...
  • Subscribers 163
  • Views 13754
Allegro – Tip of the week: Save and Restore your UI settings
PCBTech
PCBTech over 4 years ago
Allegro offers the flexibility to customize the location of the windows and toolbar icons. If, for some reason, your UI is reset to the Cadence default environment, you may want to consider the steps below to restore your custom environment.
The first step would be to establish your preferred environment.
  • To save your customized environment, go to View > UI Settings > Save Settings and then provide a filename.
  • To restore your custom environment, go to View > UI Settings and then select the saved name from the list.
Team PCBTech
Cadence Design Systems
