  3. Allegro - Tip of the Week: Do you know that you can have...
  • Replies 7
  • Subscribers 167
  • Views 9784
Allegro - Tip of the Week: Do you know that you can have your design autosaved at regular intervals?
PCBTech
PCBTech over 4 years ago
You can set the autosave feature in your design, which helps in saving your work periodically. The key variables to autosave the database are present under the File_management section in User Preferences Editor. You can open this using Setup > User Preferences.
  • autosave: Set to enable autosaving
            This option must be set before starting the layout editor.
  • autosave_dbcheck: Set to run a quick database check before an autosave
            By default, this option is turned off to save time. It requires a restart.
  • autosave name: Specifies the base name for the autosave file
           The default name is AUTOSAVE. Do NOT provide a file extension. The layout editor will use the appropriate extension based on the type of database under edit. It requires a restart.
  • autosave time: Specifies the autosave intervals
            The default time is 30 minutes. The minimum is 10 minutes, and the maximum is 300 minutes. It requires a restart.
Team PCBTech
Cadence Design Systems
  • Schulz Jordan
    Schulz Jordan over 3 years ago +1
    There are 2 challenges here 1. The minimum save time is 10min and in many cases it may not be sufficient. Are there any future updates planned to reduce the minimum save time ? 2. As the other user…
  • Jeff H
    Jeff H over 3 years ago in reply to PCBTech +1
    I would put a second vote for being able to set a location for the autosave files.
  • PCBTech
    PCBTech over 3 years ago in reply to Schulz Jordan
    Hi Schulz Jordan, thanks for the feedback. Currently the minimum save time is 10 min, reducing this would make it very frequent and can be burdensome for large designs.  Also, for the second point, currently the autosave files will be there in your current working directory.  Cadence will evaluate this request for the upcoming releases in future.
  • Jeff H
