  3. Comparing schematic netlist to pcb database
  • Subscribers 166
  • Views 13327
HSID
HSID over 4 years ago
Is there a way to compare the schematic netlist in Orcad (.dat) files to the allegro pcb editor to be sure they are in sync.
  • DS1995
    0 DS1995 over 4 years ago
    From the user interface I use the new utility "Update layout" and "Update Schematic" to compare the Schematic netlist with the board and vice versa. Before we do any changes and click on update, we are able to see the differences between schematic and layout. It shows all the differences which might occur in design cycle (like connectivity differences, refdes changes, constraints etc. between schematic and board). Here is some more information on it:-
    (+) Syncing schematic and layout has never been easier! - Capture CIS - PCB Design - Cadence Community
  • Leotordo
    0 Leotordo over 4 years ago
    Usually I do this at the end of any project
    from schematic I create a new pcb and I save XML file from Tool-->More-->Design Compare
    then I open the final layout and I open the previous XML in Design Compare
    This procedure reports net and part differences and also produce a repor file if all is sync (I attach this file to the final documentation)
    Regards
    Stefano
  • Micheal schenk
    0 Micheal schenk over 4 years ago
    The latest feature of the update layout/ update schematic makes sure you have both netlists in sync. I would say it is almost impossible to have any mismatch when this feature is used.
