  3. Matched group - Analyze choses wrong pin pair target
  • Replies 7
  • Subscribers 167
  • Views 5097
Fredda
Fredda over 4 years ago
I have a matched group that seems to chose the wrong target pin pair when running the Analyze command. Is there a reason for not choosing the longest trace (DQ21)? See below screen capture.
By the way, how is the Delay column calculated?
/F
  • avant
    0 avant over 2 years ago in reply to Fredda
    After I make these kind of changes, I run a database check. Otherwise, the changes are not implemented correctly.
  • jc teyssier
    0 jc teyssier over 2 years ago in reply to steve
    Warning with this solution:
    Without target, all nets or pin pair in match group will have same length.
    example: 1mm; everyone will be between 1mm from all others maximum
    With target, all nets or pin pair in match group will have same length RELATIVE to the target
    So if a net is +1mm from target and an other one -1mm from target, then some nets can be 2mm from them in length.
    This is not the same result
