  3. Matched group - Analyze choses wrong pin pair target
  • Replies 7
  • Subscribers 167
  • Views 5096
Fredda
Fredda over 4 years ago
I have a matched group that seems to chose the wrong target pin pair when running the Analyze command. Is there a reason for not choosing the longest trace (DQ21)? See below screen capture.
By the way, how is the Delay column calculated?
/F
  • steve
    0 steve over 4 years ago
    THis could be related to the Pin delay which will add length to the pinpair. The tools take this into account when calculating a target value.
  • Fredda
    0 Fredda over 2 years ago in reply to steve
    I never followed up on this two years ago, which I should have. Because I'm now facing the same problem again and I've forgotten how I solved it last time...
    This time I don't have any pin delay so couldn't be that. What I've noticed is that ETH_C_REF_CLK, which should be the target, has two vias in the trace and Allegro seems to have not included those vias in the length calculation when choosing the target.
    Can I manually choose a new target? I haven't found a way to do that.
    /F
  • steve
    0 steve over 2 years ago in reply to Fredda
    Make sure you enable Z-Axis Delay (Setup - Constraints - Modes - Electrical) which should then take via length into account. If you want to set your own target then simply right click on the Delta:Tolerance column for the net you want as the Target.
  • Fredda
    The Z-Axis Delay is activated and the length of the ETH_C_REF_CLK net is 25.314 mm, which includes the vias as far as I understand. The other value given for ETH_C_REF_CLK in the table, 22.284 mm should be the length without the vias and seems to be the value Allegro is using when setting the TARGET.
    I tried right clicking the Delta:Tolerance column to chose the TARGET, but couldn't see that it had an effect. It didn't seem to get updated properly. I will try again. Thanks.
  • Fredda
    0 Fredda over 2 years ago in reply to Fredda
    So, I've got it working now. Not exactly sure what was going on, but I suspect Allegro is sensitive to in which order things are made. When I manually set the target to ETH_C_REF_CLK, the Delta:Tolerance column changed to TARGET, but the previous target still had the Actual column set to TARGET. Then when clicking on Analyze the Relative Delay column headers turned to yellow as if they were not being active. I ended up with removing the matched group and creating it again, which seems to have solved the problems.
