  3. Allegro - Tip of the Week: Want to delete a via that is...
  • Subscribers 163
  • Views 4013
Allegro - Tip of the Week: Want to delete a via that is part of a via stack?
PCBTech
PCBTech over 4 years ago
Want to delete a via that is part of a via stack instead of deleting the entire via stack?
Use Edit → Delete. Make sure that vias are selected in your Find panel. Left-click on the stacked via to select it, and then use the RMB (Right Mouse Button) → “Split Stack …" command. From the popup list, select the layer pair that needs to be deleted.
Team PCBTech
Cadence Design Systems
