  3. Changing layer with keybind
  • Views 10391
FilipSwe
FilipSwe over 4 years ago
Hi all,
I am quite new to this and I have been trying to find an answer but with no success.
I'm trying to make use of keybinds to change layer view.
I have put the following in my ENV file and it almost works:
funckey NUM3 "colorview load File: Bottom_All"
In the program i get the following:
What do I need to add/change to get it to work?
Using Cadence Allegro PCB editor 17.4.
Thanks in advance!
  • steve
    0 steve over 4 years ago
    Try:- funckey NUM3 'QtSignal ColorVisibilityPane CVPViewDropdown CurrentIndexChanged "File: Bottom_All"'
  • FilipSwe
    0 FilipSwe over 4 years ago in reply to steve
    Thank you! I also noticed that NUM3 made it fail for some reason. I will be using ~3 instead (Ctrl + numpad 3), found that in another post.
