  3. Insufficient Inner Spacing Error
  • Views 10149
sujowens
sujowens over 4 years ago
I am working on a board and used freedfm to do a check. I keep getting insufficienc inner spacing error but I have made all of the min trace widths 0.005". Has anybody come across this issue and figured out where i can change this parameter?
  • steve
    0 steve over 4 years ago
    You also need to check the values in Constraint Manager - Spacing - Spacing Constraint Set - All Layers and make sure they are also set. Repeat for the Same Net Spacing worksheet as well. The min line spacing you have shown in the graphic is for Differential pairs only.
