  3. How to modify all the packages in my library easily ?
  • Views 10718
DBTCH
DBTCH over 4 years ago
Hi all ,
I need to change some information from one layer to a new one in all the package , some thousands of parts Unamused .
Is there a way to do that with a magic wand ?
Thank you for you help ?
  • mahimag
    0 mahimag over 4 years ago
    Hey,  If you want to perform same commands on all of your library parts try this. Start recording a script (File > Script > Record)  and perform all the commands you want on your part(*.dra) , save the dra while the script recording is on and in the end do not stop the recording just do a File > Exit. This will generate a scr file which can be replayed using a batch file on all of your library parts.
    batch file contents can be:
    set noconfirm=t
    for %%f IN (*.dra) DO start /wait allegro -<LicenseName> -s scipt_name.scr %%f
  • DBTCH
    0 DBTCH over 4 years ago
    Thank you for your help .
    I will try this way .
  • chrishen
    0 chrishen over 4 years ago in reply to DBTCH
    It works, thank you so so much
    smash karts
