  3. BOM including "mirrored" - information?
  • Views 3631
Manfred1
Manfred1 over 4 years ago
I was asked to provide a BOM (bill of materials) containing the information, if the part is placed TOP or BOTTOM, meaning being mirrored or not.
Of course, the preferred place to generate the BOM is the schematic programm (Capture), but there TOP/BOTTOM information doesn't exist. In Orcad PCB Designer several reports are preconfigured and can be edited, but it seems, that the fields manufacturer and part number do not exist in that software. Is that correct?
  • mahimag
    mahimag over 4 years ago +1
    Hey, to check whether the symbol is mirrored or not use SYM_MIRROR and for manufacturer and part number you can add COMP_PART_NUMBER and COMP_MANUFACTURER in your extracta command file along with the other…
  • mahimag
    0 mahimag over 4 years ago
    Hey, to check whether the symbol is mirrored or not use SYM_MIRROR and for manufacturer and part number you can add COMP_PART_NUMBER and COMP_MANUFACTURER in your extracta command file along with the other fields you have in your txt file to generate BOM report in allegro.
  • Manfred1
    0 Manfred1 over 4 years ago in reply to mahimag
    Thank you for your answer. Obviously the level of skill it requires exceeds mine.
    I found out, that the text files defining the available reports are stored at C:\Cadence\SPB_17.4\share\pcb\text\views on my PC.
    I followed your suggestions and created a text file called bom_rep_tb.txt. Using the field COMP_MANUFACTURER generated the error ERROR(SPMHDX-14): Field 'COMP_MANUFACTURER' is unknown. I deleted that field, and the file worked, but the column COMP_PART_NUMBER stays empty.
    Is there a list of all available fields in Orcad PCB Designer? Probably with the data those fields contain within the actual sample project?
    Where is the list of available Quick reports stored, that is displayed at menu item Tools / Quick Reports? Would I need to add my newly generated report manually into that list if I wanted it to be included?
  • mahimag
    0 mahimag over 4 years ago in reply to Manfred1
    Try adding the below lines in a text file and save it in your current working directory, you can see the entry with the file name in the tools > reports list. It is working for me.
    COMPONENT
    SYM_NAME
    COMP_DEVICE_TYPE
    COMP_VALUE
    COMP_TOL
    COMP_CLASS
    SYM_MIRROR
    REFDES_SORT
    REFDES
    COMP_PART_NUMBER
    COMP_MANUFACTURER
    END
    Also, part_number comes as a component property, you can check if your compoents have this property or not.
    I can see the complete list of fileds on the Cadence Support website,https://support.cadence.com/apex/techpubDocViewerPage?xmlName=algrodescmp.xml&title=Completing%20the%20Design%20--%20Extracting%20Views%20from%20the%20Layout%20Editor%20-%20Baseview%20File%20Contents&hash=pgfId-1034643&c_version=17.4-2019&path=algrodescmp/algrodescmp17.4-2019/chap5.html#pgfId-1034643
