  3. Moving Mechanical Symbol
  • State Verified Answer
  • Views 12678
jmadsen
jmadsen over 4 years ago
I am running OrCad PCB Designer Professional V 17.4 S027.  I placed a slot as a mechanical symbol on my PCB.  I want to move it.  No matter what I've tried, I cannot select it to move or delete.  I've tried in both Placement Edit and General Edit modes.  I've used "All On" on the Find Filter.  Anyone have any ideas?
Thanks!
  • jmadsen
    jmadsen over 4 years ago +2 verified
    It seems that the problem is that nothing on the slot is "visible," and therefore cannot be selected. I put visible in quotes because I can see a grey oval where the slot is, but it is not technically…
  • mahimag
    0 mahimag over 4 years ago
    check for FIXED or LOCKED property on symbol
  • jmadsen
    0 jmadsen over 4 years ago in reply to mahimag
    One of the first things I tried was to UNFIX it. I get a "No element found." message, no matter how I set my find filter for all commands - UNFIX, MOVE, DELETE, etc.  Is LOCKED a separate property from FIXED?
  • jmadsen
    +1 jmadsen over 4 years ago
    It seems that the problem is that nothing on the slot is "visible," and therefore cannot be selected.  I put visible in quotes because I can see a grey oval where the slot is, but it is not technically visible to OrCad.  So, I can just go to the Color Dialog -> Stack-up and check Soldermask Top (or Bottom) -> Pin.  That makes a part of the slot visible, and therefore selectable.  Thanks Colton Knight for pointing me in the right direction!
    • Vote Up +2 Vote Down
  • moseschanx
    0 moseschanx over 2 years ago in reply to jmadsen
    This bro gives the feasible answer, thanks a lot!
