  3. Allegro - Tip of the week: Using the Delete by Rectangle...
  • Subscribers 163
  • Views 2179
Allegro - Tip of the week: Using the Delete by Rectangle command
PCBTech
PCBTech over 4 years ago
There is a quick and easy way to cut through several tracks at once. Use the “Delete by Rectangle” command to make a window cut in a group of clines. Access the command from Manufacture > Drafting > Delete By Rectangle.
Follow the instructions in the Command Window:
  1. First, select the objects to cut.
  2. Choose the upper-left corner of the cutting window.
  3. Choose the lower-right corner of the cutting window.
Team PCBTech
Cadence Design Systems
