  3. How to update shape in one of layers?
  • State Verified Answer
  • Replies 7
  • Subscribers 167
  • Views 15956
David Lin
David Lin over 4 years ago
I want to update only one layer not all.
  • luanvn81
    luanvn81 over 4 years ago +1 verified
    Hi David! Hope below code can help you. axlCmdRegister( "uds" `update_shape_layer) (defun update_shape_layer () All_shapes = axlDBGetShapes("ETCH") All_shapes = setof(el All_shapes el->shapeBoundary…
  • excellon1
    0 excellon1 over 4 years ago
    In the find filter select shapes. On the tool bar look for the shape select Icon. It looks like an open arrow. Click on the shape then right click Update. Right click and select done after the update completes.
  • David Lin
    0 David Lin over 4 years ago in reply to excellon1
    Thanks your reply.
    I know this way.
    I'm running a huge board. It have lots of shape,etch,32 layers cause Allegro is very slow.
    If there have the ways can only update one layer's shape. It can be more efficient.
  • luanvn81
    +1 luanvn81 over 4 years ago
    Hi David!
    All_shapes = setof(el All_shapes el->shapeBoundary != nil)
    update_layers = nil
    sub_info = car(setof(e axlVisibleGet() member("ETCH" e) != nil ))->subclassinfo
    sub_vis = reverse(setof(e sub_info cadr(e) == t))
    if(sub_vis != nil then
    foreach(item sub_vis
    update_layers = cons(strcat("ETCH/",car(item)) update_layers)
    );end foreach
    update_shapes = setof(el All_shapes member(el->layer update_layers) != nil)
    printf("Selected layers:%L\n", update_layers)
    foreach(shape_id update_shapes
    aa = axlShapeDynamicUpdate(shape_id->shapeBoundary t)
    if(aa != 0 then printf("update failed\n"))
    );end foreach
    );end if
    );end defun update_shape_layer
    Luan.
  • David Lin
    0 David Lin over 4 years ago in reply to luanvn81
    Hi Luan,
    That's Awesome!!!!
    I'll give it a try!
    Thanks a lot.
  • JITHINDEV
    0 JITHINDEV over 4 years ago in reply to luanvn81
    Hi Luan,
    How to run this skill code.
    Jithindev
