  3. Select/group component using schematic PDF
  • Views 2396
MANI BHARATHI
MANI BHARATHI over 4 years ago
Dear All,
I have schematic pdf only no .DSN file, need to do placement using PDF. is there any skill to select component using PDF, or else we need to go PDF and see refdes and find in layout is there any easy possible way. please suggest. Tool allegro 16.6
  • Robert Finley
    0 Robert Finley over 4 years ago
    Best layout tool I have ever found.  Allegro and a plugin called "CircuitSpace".   You can get a license from EMA-EDA.
    https://www.ema-eda.com/products/ema/circuitspace
    Has a plugin for Adobe Acrobat that gives you a crossprobe communication feature, even as you are routing the board.
    Curious if you have an intelligent PDF for it to read though.   I think it started out as a method to crossprobe DXDesigner/ViewDraw schematics.
