  3. Hi, where to get supports about "property edit"?
  • State Verified Answer
  • Views 2442
RobertLiang
RobertLiang over 4 years ago
Hi experts,
I've searched but there's no result.
I was inspired to use the "edit property" function in "allegro PCB designer" to control the individual shape/pin/via's design rules (e.g. clearance spacing, thermal relief types), and I believe the "edit property" function can realize far more than that.
But there're a lot of properties available, and their name is abbreviated and unclear (I have to guess their meanings). Where can I know the function of each property? (Is there a detailed tutorial or documentation?)
Thank you!
  • Ejlersen
    Ejlersen over 4 years ago +1 verified
    Hi You can find information about all these properties in the Allegro Platform Properties Refernce guide. It is part of the online help - look in Allegro PCB Editor -> Allegro Platform Properties Reference…
  • Ejlersen
    +1 Ejlersen over 4 years ago
    Hi
    All the properties for controlling dynamic shape connect, spacing etc. are named DYN_
    You can also find a direct reference in C:\Cadence\SPB_17.4\doc\propref
    Best regards
    Ole
