  3. DRC error when adding fillet (teardrop)
  • Views 10377
Fredda
Fredda over 4 years ago
Is a fillet considered to be part of the pad to which it is added? It seems like the DRC checker thinks so since it is complaining about "Thru Pin to Thru Pin Spacing". However, the spacing between the pins are less than 0.4 mm even without the fillet so I don't now why there's no DRC error even without the fillet. The grid is 0.1 mm.
/F
  • Schulz Jordan
    0 Schulz Jordan over 4 years ago
    Goto - Display - element & click on DRC (which is highlighted) & look at the cordinates. The fillet should not be considered under thru pin - thru pin spacing error.
