  3. Create a report for extracting the information of min track...
  • State Suggested Answer
  • Answers 2
  • Subscribers 166
  • Views 15137
Create a report for extracting the information of min track width and min spacing
Ramadas
Ramadas over 4 years ago
How to create a report for extracting the information of minimum track width and minimum spacing information in the PCB editor?
  • steve
    steve over 4 years ago +1 suggested
    Look at Tools - Reports, there is a list of default reports which may help but if not click on New/Edit and you can choose which items you want to add to a report template.
  • steve
    0 steve over 4 years ago
  • Ramadas
    0 Ramadas over 4 years ago in reply to steve
    Thanks for the response, I have tried that option, but I am not getting any options for adding minimum track width and minimum spacing in the report. Which database do I want to choose for getting the options like minimum track width and minimum spacing?
  • DavidJHutchins
    0 DavidJHutchins over 4 years ago in reply to Ramadas
    The extracta/report functionality is based upon reading the Allegro database,
    however the minimum track width and minimum spacing values are stored in the 'constraint' data, which I think is accessible only using skill
  • DavidJHutchins
    0 DavidJHutchins over 4 years ago in reply to DavidJHutchins
    Below is some skill code that will scan the constraints to find the minimum width & spacing values...
    procedure(min_width_space() let((min_width min_gap phys_width phys_gap phy_csets spc_list sps_csets data) ;# phy checks (min_width = 9999.999) (min_gap = 9999.999) ;#(phys_list=axlCNSGetPhysical(nil nil nil)) (phys_width=list('neckwidth_min 'width_min)) (phys_gap=list('dp_min_gap 'dp_neck_gap 'dp_primary_gap)) (phys_csets = axlCnsList('physical)) foreach(cset phys_csets when(equal(cset "DEFAULT") (cset="")) foreach(chk phys_width foreach(subclass axlSubclassRoute() (data = axlCNSGetPhysical(cset subclass chk)) when(and(realp(data) greaterp(data 0.0) lessp(data min_width)) axlMsgPut("cset %s chk %L old=%f new=%f" cset chk min_width data) (min_width = data) ) ) ) foreach(chk phys_gap foreach(subclass axlSubclassRoute() (data = axlCNSGetPhysical(cset subclass chk)) when(and(realp(data) greaterp(data 0.0) lessp(data min_gap)) axlMsgPut("cset %s chk %L old=%f new=%f" cset chk min_gap data) (min_gap = data) ) ) ) ) ;# spc checks (spc_list = axlCNSGetSpacing(nil nil nil)) (spc_csets = axlCnsList('spacing)) foreach(cset spc_csets when(equal(cset "DEFAULT") (cset="")) foreach(chk spc_list foreach(subclass axlSubclassRoute() (data = axlCNSGetSpacing(cset subclass chk)) when(and(realp(data) greaterp(data 0.0) lessp(data min_gap)) axlMsgPut("cset %s chk %L old=%f new=%f" cset chk min_gap data) (min_gap = data) ) ) ) ) (axlMsgPut "Min_Width %f Min_Gap %f" min_width min_gap) ) )
  • Yuva09
    0 Yuva09 over 3 years ago in reply to DavidJHutchins
    I saved this skil fil with *.il , then what is the axlCmdRegister("XXXX", 'XXXXX") for run this skil
