  3. Gerber Parameters - Decimal places not up to Ucamco sta...
  • State Suggested Answer
  • Answers 1
  • Views 4114
Gerber Parameters - Decimal places not up to Ucamco standard
Fredda
Fredda over 4 years ago
In the Artwork Control Form (Export -> Gerber Parameters) at the General Parameters tab, the number of integer and decimal places for Gerber export are set in the Format box. It seems like I can set any number here, but the documentation says that the number needs to be between 0 and 5. Looking at the FS command line in the generated Gerber file, it seems like the documentation is right. Setting 6 decimals will only get you 5 decimals (%FSLAX45Y45*MOMM*%).
Anyhow, the problem is that the Gerber Layer Format Specification (https://www.ucamco.com/files/downloads/file_en/416/the-gerber-layer-format-specification-revision-2021-02_en.pdf) strongly suggest to use 6 decimals.
Page 47:
"Always use metric, with 6 decimals.
It is sometimes argued that 6 decimals is overkill as the PCB design grid is much coarser. This
is not a valid argument. Many points in a Gerber file are calculated; intersections, certainly with
circles, have rational or even irrational coordinates, resulting in rounding errors. Even small
perturbations can turn an otherwise perfect arc into an invalid one or turn an impeccable contour
in an invalid self-intersecting one. Most errors such as missing clearances have low resolution
as root cause and are solved when metric 6 mm is set. There only downside to high resolution
is that the file becomes about 5% bigger, which is not a reason to throw away precision and risk
scrap. There is no reason to use antiquated imperial units. An underlying component or design
grid may be imperial, but a nm unit expresses any imperial value of 1/100 mil or larger without
rounding error – amply sufficient for PCBs. By using inch, which is 25.4 times larger than mm,
one gives up precision for no gain"
What am I to think about this? Shouldn't a leading PCB CAD tool meet the Ucamco recommendations?
/F
  • JuanCR
    JuanCR over 2 years ago +1 suggested
    Hi Fredda, Concerning your notes on the way Gerneral Parameters work in Artwok generation, I think there is a slight misunderstanding. Let me first explain what I've found so you can correct me if…
  • Fredda
    0 Fredda over 2 years ago
    Still no feedback on this... Is anyone still using Gerber or has everyone switched to ODB++ or IPC-2581?
    /F
  • gvellet
    0 gvellet over 2 years ago in reply to Fredda
    Our CM is Sanmina, they are also ordering the PCB fabrication for us. We provide them with both Gerber package and the ODB++ file. They are OK with Gerbers but they prefer ODB++ because it included the netlist connectivity. They never asked for ipc-2581.
    Perhaps we should stop providing them with the Gerber package but it is an old habit.
  • JuanCR
    0 JuanCR over 2 years ago
    Hi Fredda,
    Concerning your notes on the way Gerneral Parameters work in Artwok generation, I think there is a slight misunderstanding. Let me first explain what I've found so you can correct me if I'm wrong: when going through the text of page 47, it seems as if the document is talking about Decimal places. They recommend it should be 6. Additionally, I've also read in page 46 that Integer places range from 1 to 6, but it depends on the size of the board and a typical value is 3.
    Now, if you see the general parameters section of the Artwork Control Form:
    When you select the Integer places, the range shown below is 0 - 5. And when you select the Decimal places, the range is now 0 - 6. Both parameters are within specs of Ucamco, and most importantly, the decimal one is.
    So, let me know if there was a confusion about these numbers and how I can help you further.
    The thread still stands as a valid discussion on the topic of which format is more popular. But I wanted to clraify this technical tool-specific aspect with you.
