  3. SPB17.2 PCB Designer software err. I can't open visibil...
  • Subscribers 159
  • Views 1589
SPB17.2 PCB Designer software err. I can't open visibility
Yosef Wang
Yosef Wang over 3 years ago
When I try to turn on the visibility option in PCB Designer software, I get the error popup below. I have reinstalled the software and the error is still there. would you help me with this problem?
Thank you!
  • JuanCR
    0 JuanCR over 3 years ago
    Hi! This can be caused by many reasons. Have you tried the usual suspects?:
    - start allegro in safe mode
    - start allegro with -noopengl option
    - delete your pcbenv folder and then start allegro
  • Schulz Jordan
    0 Schulz Jordan over 3 years ago in reply to JuanCR
    Also update the hotfix SPB 17.2 S083 as you are running on P028
