  3. Allegro - Tip of the week: Displaying properties in the...
  • Views 2942
Allegro - Tip of the week: Displaying properties in the canvas
PCBTech
PCBTech over 4 years ago
Here is a tip which can be used to display the properties attached to your design elements.
Properties attached to an element can be displayed in the canvas using the Display > Property menu.
Select the Graphics tab, and then select the properties to display from the left column. Clicking the Create button writes out the property values and/or the respective names to the Manufacturing class subclass properties.
You can also write “show property" in the command-line window to launch the Show Property dialog box.
Team PCBTech
Cadence Design Systems
  • zestyscourge
    zestyscourge over 4 years ago
    Select the Graphics tab, and then from the left column, choose the properties you want to display. The corresponding names and/or property values are added to the Manufacturing class subclass properties by clicking the Create button. flagle
