  3. Is it possible to create a netlist from command window in...
  • Views 10634
Is it possible to create a netlist from command window in Capture ?
Schulz Jordan
Schulz Jordan over 4 years ago
I want to create the netlisting files from windows command window. Is it possible ?
  • DavidJHutchins
    0 DavidJHutchins over 4 years ago
    I searched https://support.cadence.com/ for "allegro system capture tcl netlist" & found this:
    #command to generate a Physical Netlist for root design
    exportPhysical pcb genpkg
  • DavidJHutchins
    0 DavidJHutchins over 4 years ago in reply to DavidJHutchins
    I don't think you can do this from a windows command window, but you should be able to write a script that invokes capture, opens the design & then generate the netlist
  • jc teyssier
    0 jc teyssier over 2 years ago
    This is what i do.
    In windows cmd just type
    pstswp.exe -pst -d <your_dsn_name.dsn> -n allegro -c <your path to config file>/allegro.cfg -v 3 -l 255
    -v 3 is verning number for .dat files (,1 ,2 ,3)
    -l 255 is to indicate that name length limit is 255 intead of 31 wihch is default.
