  3. One drill is missing in the drill chart
  • Views 10612
Devan
Devan over 4 years ago
In my Gerber file and drill chart one drill (npth) is missing. in pad stack editor it was defined as plated drill with no design layer (only mask was defined as drill size).
Is there is any solution to solve this issue that any drill does not gets missed in the Gerber/ drill charts.
  • Vipulc
    0 Vipulc over 4 years ago
    In such requirement, best practice is to add some value to Regular Pad while defining Pad Stack. Make this value less then the Finished Diameter.
  • avant
    0 avant over 4 years ago
    If the drill is intended to be npth, define it as npth.
    You can add pads smaller than the drill size.
