  3. Artwork and NC Drill scaling mismatch
  • State Suggested Answer
  • Answers 1
  • Views 11759
SLSCORP
SLSCORP over 4 years ago
The scaling of NC drill does not match the scaling of other layers artwork. NC drill size looks bigger than the artwork in gerber viewer. What settings I need to change to match scaling of NC Drill with the Artwork?
  • oldmouldy
    oldmouldy over 4 years ago +1 suggested
    The issue is with the Gerber viewer misinterpreting the drill data format. For example, you may have exported the drill data as 2.4, two integer places and 4 decimal places but the Gerber viewer is interpreting…
  • oldmouldy
    0 oldmouldy over 4 years ago
    The issue is with the Gerber viewer misinterpreting the drill data format. For example, you may have exported the drill data as 2.4, two integer places and 4 decimal places but the Gerber viewer is interpreting this as 3.3, effectively 10 times larger. Gerber viewers typically have a way to override the default settings for the drill data import so that the correct format can be set.
