  3. Allegro - Tip of the Week: Preventing Shorts
  • Subscribers 163
  • Views 1498
PCBTech
PCBTech over 4 years ago
It is possible to override a DRC using properties in PCB Editor. Most of the times, we do it on purpose, with a goal in mind. However, we can’t rule out those other times where an oversight might cost us time and money because of a short in our design.
Here’s a checklist you can follow to avoid this situation:
  1. Make sure that the nets involved do not have the “NO_DRC” property on a pin(s).
  2. Make sure there are no invalid “waived DRCs”.
  3. Make sure your DRC modes are enabled. Be especially careful with newly released DRCs (for example, Microvia-based), as those are disabled by default.
  4. Run DBDoctor (Database check) to keep the design in sync and up to date.
  5. Make sure the plane layers in the cross-section form agree with the artwork control form (negative or positive).
  6. Make sure the padstacks are designed properly; both Antipads and thermals.
Team PCBTech
Cadence Design Systems
