  3. Write to File without double quotes
  • State Verified Answer
  • Views 11688
khuranav007
khuranav007 over 4 years ago
When I write a string to file then the string gets written with double quotes.  How can this string be written without double quotes?
I have played with parseString() and buildString() and couple of other SKILL functions but so far haven't figured this out - any clues?
"GND_TX_LO,GND_TX_BALUN,M4"
Thanks for help
  • DE202408202727
    DE202408202727 over 4 years ago in reply to khuranav007 +1 verified
    Use %s for strings. ie. fprintf(myport "%s\n" getVal)
  • DE202408202727
    0 DE202408202727 over 4 years ago
    How can we possibly help you without seeing the command string that you are using?
  • khuranav007
    0 khuranav007 over 4 years ago in reply to DE202408202727
    Thanks for the response Dave.  I assumed that this is a common problem.
    If you mean how I am writing to file here's the command:
    fprintf(myport "%L\n" getVal)
  • DE202408202727
    +1 DE202408202727 over 4 years ago in reply to khuranav007
  • khuranav007
    0 khuranav007 over 4 years ago in reply to khuranav007
    Hi Dave,
    I think I know why you asked for the command string Slight smile
    I replaced %L to %s and it works now.
