  3. Vias in Hatched copper fills
  • Views 10195
bbertiaux
bbertiaux over 4 years ago
I'm trying to get Allegro to properly connect ground vias to a hatched ground plane. It seems to work sometimes and not others.  Comparing designs, I am failing to find an obvious setting to make this work.  I have the setting in the parameters to do Orthogonal which has worked in the past.  Not this time.  Both images are using the same constraints and via, and same parameters.  The top image will not update to accommodate the vias like the second image. Any ideas?
  • RFinley
    0 RFinley over 4 years ago
    Shapes set to dynamic and up to date?
    Usually happens on stitching vias opening a translation.  Shapes start as static.
