  3. error in startup script
  • Subscribers 167
  • Views 11012
myil17
myil17 over 4 years ago
I get the this error when I open a project. What might be the reason for that?
We moved to one drive environment and there is a space in the file extension after Onedrive.
Could it be the reason? We can't change the space in the file name at the moment.
Is there a way to synch it with a space in the file name?
  • Vipulc
    0 Vipulc over 4 years ago
    One of the reason could be the permission to you HOME folder or the Project location folder.
  • jc teyssier
    0 jc teyssier over 4 years ago
    One tip: same parts of alletro do not handle well space in file name or directory path: space will be considered as a separator.
    I see you have "onedrive - xxxx/Box Migration" in path: try an other location  for projects (without space in the name)
    To avoid such kind of proble$ln, restrcit path and names wtih "standard" caracter: a-z, nubees - , _
    Do not use , ; $ é à @ and so on
  • Dallas Steele
    0 Dallas Steele over 4 years ago in reply to jc teyssier
    oh thank you su much, that really helpful.
    snake io
