  3. Incorrect Via is Being Placed
  • State Suggested Answer
  • Answers 1
  • Views 11006
CPFLEX
CPFLEX over 4 years ago
I have some blind vias in my design. The vias I have in the desing are:
1. Default Via
2. Blind via from Top to Layer 2
3. Layer 2 to Layer 3
4. Layer 3 to layer 4
5. Layer 4 to Layer 5
6. Layer 5 to Bottom
Everytime time I try to place via 2 through 6, it just places the default via. I've checked the padstack and I defined the via in the blind and buried via option in setup before putting them in the desgin through the constraints
  • steve
    0 steve over 4 years ago
    So this is usually related to the via list. If the default via is at the top of the vialist it will alwyas be used. You need to make sure that the bbvias are above it. Watch this:- Cadence PCB Blind Buried Single Click Multiple Via Instantiation - YouTube
  • CPFLEX
    0 CPFLEX over 4 years ago in reply to steve
    Unfortunately that have no effect. I actually removed the via from the list and the program is still placing the via that has a 13 mill drill instead of the the 4 that I'm expecting
  • Master Shifu
    0 Master Shifu over 4 years ago in reply to CPFLEX
    Try purging unused padstacks. Tools > Padstacks > Modify design padstacks - Purge - RMB > All.
