  3. Copper pour around pin
  • Views 10427
jatins
jatins over 4 years ago
Hi
I have a 3-pin through hole connector in my design. And 1 of these 3 pins is connected to Ground.
I want to increase the distance between this GND Pin and the surrounding Copper Pour on that layer as shown below
so that the tracks from Hole to surrounding Copper Pour become longer:
Is there a nice way to do this without affecting the whole design.
  • oldmouldy
    oldmouldy over 4 years ago +2
    Check that Pins are enabled in Find and no commands are active. Select the Pin, or Pins. Hover over the selection (just the Pin if there is only one), right-click>Property Edit, in the Property Editor…
  • oldmouldy
    0 oldmouldy over 4 years ago
    Check that Pins are enabled in Find and no commands are active. Select the Pin, or Pins. Hover over the selection (just the Pin if there is only one), right-click>Property Edit, in the Property Editor, locate Dyn_Clearance_Oversize_Array and left-click to add the Property. Then left-click>Assign and assign the oversize value to the required Layer(s), or Layer Group(s), OK through the forms to accept the change.
    • Vote Up +2 Vote Down
