  3. Find: Text and Lines Option unselectable in OrCAD PCB
  • Subscribers 166
  • Views 10588
jatins
jatins over 4 years ago
Hi
I have some text and lines which i want to move from for example: DrawingFormat> Outline to Drawing Format> Title Block.
But it is not possible to do it right now. This works with shape option.
So, dodn't know if i had made any changes in Settings or did it happen after recent hotfix.
  • mahimag
    mahimag over 4 years ago +1
    Try Edit > Change, select the desired class/subclass in the options window and select the "text" and "lines" in the find filter and then select the lines and text on the canvas you want to change to Drawing…
  • mahimag
    0 mahimag over 4 years ago
    Try Edit > Change, select the desired class/subclass in the options window and select the "text" and "lines" in the find filter and then select the lines and text on the canvas you want to change to Drawing Format/ Title Block class .
