  3. How remove existing DRC ?
  • State Suggested Answer
  • Answers 1
  • Views 13269
Uri Chaplin
Uri Chaplin over 4 years ago
Sometimes when I work created DRCs. I disable online check but DRCs is already exist.
How remove it ?
  • SOT23
    SOT23 over 4 years ago +2 suggested
    Hello, if by "remove" you mean deleting it, I don't think it is possible to do so. The only way to get rid of a DRC, to my understanding, are : making sure the constraint is not violated anymore …
  • SOT23
    0 SOT23 over 4 years ago
    • making sure the constraint is not violated anymore
    • waive the DRC error. To do that, you can use menu Display > Waive DRCs > Waive.
    But you could also simply turn off the DRC layer you don't want to see : Display > Color/Visibility, then turn on or off the DRC layers.
    Still in that "Color Dialog" window, you can go to the "Visibility Pane" and remove the DRC class from the "Visible Classes" by cliking on the down arrow. This way when you show a layer using the little button in the Visibility tab, it will not display DRCs.
    • Vote Up +2 Vote Down
  • Uri Chaplin
    0 Uri Chaplin over 4 years ago in reply to SOT23
    Hi !
    I want to make it by SKILL ...
