  3. create a symbol
  • State Suggested Answer
  • Answers 1
  • Views 10749
create a symbol
masamasa
masamasa over 4 years ago
hello
i have an excel sheet with bump locations in layout as shown below.
there are no xy coordinates on those bumps.
is there a way to use this excel sheet to create a symbol?
regards
masa
  • oldmouldy
    oldmouldy over 4 years ago +1 suggested
    The answer is "obviously not" since an Excel sheet "with 'dots' for pins" has none of the required data to create a Package Symbol. You could get the Excel sheet to a text format, like CSV, and then work…
  • oldmouldy
    0 oldmouldy over 4 years ago
    The answer is "obviously not" since an Excel sheet "with 'dots' for pins" has none of the required data to create a Package Symbol. You could get the Excel sheet to a text format, like CSV, and then work from there. You would need to apply some assumptions to ease processing, but this could be done with some work. PCB Editor is going to need Pin Number, Padstack Name, X / Y location and Rotation in a CSV to import a CSV Pin file into a Package Symbol. You could start with A1 as the top left Pin Number, a "default" Padstack name to start with, an X / Y location of 0 / 0 and Rotation of 0, then work through B1, C1 and so on for the row with an increment to the X location to match the Pin pitch, then move on through the rows with Y incrementing in the Location for each row, A2, B2, C2 and so on for Pin Numbers. If you have some programming expertise, it wouldn't be that difficult to create the required CSV PIn file data to import into PCB Editor.
  • masamasa
    0 masamasa over 4 years ago
    thank u for your reply. i created the symbol manually. it tooks me 3 days. i wish there is a way to create it automatically.
