  3. Retaining ref des silkscreen location
  • Views 13227
fishcrakers
fishcrakers over 4 years ago
Hi, Good day! I have already done the PCB design and position the ref des silkscreen as well. However there are saome update on the parts . When I export physical the design. The refdes silkscreen returned to the original position and font size. Is there a way the ref des silkscreen position and font size to retain and not change even I updated the parts/components?
  • jc teyssier
    0 jc teyssier over 4 years ago
    I am afraid  no solution exist (to my knwoledge) if the footprint change.
    If footprint does not change, text should be leave at same location / size.
    If you only refrsh the footprint symbol, do not check "Reset symbol text location and size"
  • DBTCH
    0 DBTCH over 4 years ago
    Hi ,
    You can try this skill to save the refdes location and reload them ,after you update the parts .
    * DISCLAIMER: The following code is provided for Cadence customers *
    * to use at their own risk. The code may require modification to *
    * satisfy the requirements of any user. The code and any *
    * modifications to the code may not be compatible with current or *
    * future versions of Cadence products. *
    * THE CODE IS PROVIDED "AS IS" AND WITH NO WARRANTIES, INCLUDING *
    * WITHOUT LIMITATION ANY EXPRESS WARRANTIES OR IMPLIED WARRANTIES *
    * OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. *
    ; File: set_refdes.il
    ; Usage: Load this file set_refdes.il
    ; Issue the command srd <arg> on the Allegro command line. Where <arg>
    ; is a command line argument that can be either save or get
    ; srd save Saves refdes data to the file refdes.txt
    ; srd get Retrieves refdes data from the refdes.txt file.
    axlCmdRegister("srd_sk" '_set_refdes_silk_from_file ?cmdType "general")
    procedure( _set_refdes_silk_from_file( mode )
    prog( list(l_text refdes t_loc t_rot t_mirror t_justify t_layer l_vis l_old_loc mir rot)
    l_old_loc=list()
    case(mode
    ("save" ;save the current refdes text information to a file
    printf("Mode:save\n")
    printf("Saving refdes data to file refdes_silk.txt\n")
    p_refdes=outfile("./refdes_silk.txt") ;open a file to store the data
    axlClearSelSet() ;clear any selected objects
    axlSetFindFilter(?enabled '(noall text) ?onButtons '(text))
    l_vis=axlVisibleGet() ;Store the current layer visibility
    axlVisibleDesign(nil) ;Set the visibility as desired.
    axlVisibleLayer("REF DES/SILKSCREEN_TOP" t )
    axlVisibleLayer("REF DES/SILKSCREEN_BOTTOM" t )
    axlUIWUpdate(nil)
    axlAddSelectAll() ;Select all of the visible text
    l_text=axlGetSelSet() ;Save the selected text in a list
    axlClearSelSet()
    foreach(text l_text ;Check each text string
    parent_type = text->parent->objType
    text_class = car(parseString(text->layer "/"))
    if(parent_type == "symbol" && text_class=="REF DES" then
    ;probably found a refdes. Store the text details
    refdes=text->text
    t_loc=text->xy
    t_rot=text->rotation
    t_mirror=text->isMirrored
    t_layer=text->layer
    t_textblock=text->textBlock
    t_justify = text->justify
    ;write the data to a file
    println(list(refdes t_loc t_layer t_rot t_mirror t_textblock t_justify) p_refdes)
    );endif
    );end foreach refdes
    close(p_refdes) ;close the file
    axlVisibleSet(l_vis)
    axlUIWUpdate(nil)
    printf("Refdes save completed.\n")
    );save
    ("get" ;Read the file and process the text
    printf("Mode:get\n")
    l_visible=axlVisibleGet() ;store current visibility settings.
    axlVisibleDesign(nil) ;turn everything invisible
    p_refdes=infile("./refdes_silk.txt")
    while(l_refdes=car(lineread(p_refdes))
    refdes=nth(0 l_refdes)
    loc=nth(1 l_refdes)
    layer=nth(2 l_refdes)
    new_rot=nth(3 l_refdes)
    new_mir=nth(4 l_refdes)
    new_tblock=nth(5 l_refdes)
    new_justify=nth(6 l_refdes)
    l_old_loc = _find_refdes(refdes layer) ;call procedure to find the original text
    old_xy = nth(1 l_old_loc) ;current coordinates of refdes
    old_rot = nth(0 l_old_loc)->rotation ;current refdes rotation
    old_mir = nth(0 l_old_loc)->isMirrored ;current mirror status
    old_tblock=nth(0 l_old_loc)->textBlock ;current text block used
    o_component=nth(0 l_old_loc)->parent ;need the parent if creating new text
    when(old_xy ;if there is an xy then we found the text and can do a transform
    if(old_tblock==new_tblock then ;if the same text block then do a transform
    delta_x=xCoord(loc) - xCoord(old_xy) ;calculate the x offset
    delta_y=yCoord(loc) - yCoord(old_xy) ;calculate the y offset
    l_delta=list(delta_x delta_y) ;distance to move the text
    rot=new_rot-old_rot ;calculate the rotation
    mir=(new_mir && !old_mir)||(!new_mir && old_mir) ;mirror is XOR
    axlTransformObject(car(l_old_loc) ?move l_delta ?mirror mir ?angle rot) ;move the text
    else
    ;if textblocks don't match then create a new refdes.
    new_orient=make_axlTextOrientation(?textBlock new_tblock, ?rotation new_rot, ?mirrored new_mir, ?justify new_justify )
    new_refdes=axlDBCreateText(refdes, loc, new_orient, layer, o_component)
    if(new_refdes then ;if new refdes successful then delete old one.
    axlClearSelSet()
    axlSingleSelectPoint(old_xy)
    axlDeleteObject(axlGetSelSet())
    axlClearSelSet()
    );end_if
    );end_if
    );end_when
    );end while
    close(p_refdes)
    axlVisibleSet(l_visible) ;restore layer visibility.
    printf("Process complete.\n")
    );get
    (t
    printf("Invalid command line argument.\n")
    printf("Command syntax: srd save or srd get \n")
    return(nil)
    );endcase
    );endprog
    );endproc
    procedure( _find_refdes(sym tlayer)
    ;procedure to return the dbid and location of the refdes for the symbol
    prog( list(child l_children o_type o_layer match_loc)
    l_children = car(axlSelectByName("REFDES" sym))->children
    foreach(child l_children
    o_type = child->objType
    o_layer = child->layer
    if(o_type=="text" && o_layer==tlayer then
    ;probably found a refdes match.
    match_loc=child->xy
    axlClearSelSet()
    return(list(child match_loc)) ;return the dbid and location of the text
    ;if match_loc returns as nil then the text was not found
    );endif
    );foreach child
    );end prog
    );end proc _find_refdes
  • jc teyssier
    0 jc teyssier over 4 years ago in reply to DBTCH
    i have used this one in the past: woks but not fully: some mirrored text are not well handled Disappointed
    Have  a try: maybe for you it is ok.
