  3. Listing Sub Directory files
  • Views 10871
karthikeyank
karthikeyank over 4 years ago
Hi
I would like to fetch sub directory files and store that files in single list. I tried by using "getDirFiles" through this function current Dir file names only fetching. its not collecting sub Dir files can anyone plz help me out.
Main DIR:
SUB DIR1:
SUB DIR 2:
Code:
procedure(DupFileFind()
FoldNames_Inp = getDirFiles(".")
foreach(FoldNames FoldNames_Inp
if(isDir(FoldNames) then
FileOut = getDirFiles(".")
println(FileOut)
Current Output is:
("A" "B" "chk" "chk")
Expected Output is:
("a.dra" "a.pad" "a.psm")
("b.dra" "b.pad" "b.psm")
Karthi
  • B Bruekers
    B Bruekers over 4 years ago in reply to karthikeyank +1
    there was a small error, this works for me: dirSearch("c:/temp") defun(dirSearch (dir @key (maxdepth 5) ) "Function to get all files from a given directory" "maxdepth: when 0/nil only search highest…
  • B Bruekers
    0 B Bruekers over 4 years ago
    Something like this should do the trick:
        "maxdepth:     when 0/nil only search highest dir. Any other number =level of subdirs to search"
        let((files name (dirFiles  getDirFiles(dir)) tmp_ext)
        unless(integerp(maxdepth) maxdepth=0)
        while( dirFiles
            name= strcat(dir "/" car(dirFiles)) ;fetch first element of filelist. Make a full path to be able to determine if directory or file.
            dirFiles = cdr(dirFiles) ;keep remainder of filelist
            cond(
                (and( isReadable(name) isFile(name))    ;name is a file (not a directory)
                    files= cons(name files)
                (and( isDir(name)  isReadable(name) not(memv(name list("." "..")))  maxdepth>0 )  ;name is a directory, not a file.
                    ;recursive call to fetch files from the directory 'name'
                    files= append(files dirSearch(name ?maxdepth (maxdepth-1)))
        files    ;return list of files
        );let
  • karthikeyank
    0 karthikeyank over 4 years ago in reply to B Bruekers
    Thanks for the reply but it shows me error
    E- *Error* dirSearch: too few arguments (at least 1 expected, 0 given) - nil
    ERROR
  • B Bruekers
    0 B Bruekers over 4 years ago in reply to karthikeyank
      while( dirFiles
        name = car(dirFiles)
        unless(memv(name list("." ".."))
          name= strcat(dir "/" name) ;fetch first element of filelist. Make a full path to be able to determine if directory or file.
          cond(
            (and( isDir(name)  isReadable(name)   maxdepth>0 )  ;name is a directory, not a file.
    );let
